EAA Ultralight Days 2022 - Webinar- Care and Feeding of the 1/2 VW Engine
Here you’ll find URL Links to Chris Deuel's video posts on Instagram, educational, tutorial, pictures, and links to videos across the Internet that are flight based. Feel free to add links of such activities you find and share with others. Note that non-flight based links will most likely be removed except under special circumstances. Discussion reply posts are encouraged.
https://www.eaa.org/Videos/Ultralight-A ... 8605382001
(EAA Membership required to view this webinar).
Re: EAA Ultralight Days 2022 - Webinar- Care and Feeding of the 1/2 VW Engine
Interesting information. I was surprised by several things. I didn't realize that a wooden prop is mandatory with 1/2 VW's because of the vibration of the engine. I was also surprised about the comment about only 200 to 300 FPM climb rate. I expected that since the high end versions generate 45+hp and high torque that the FPM would be pretty good. The 200 to 300 FPM I think the presenter is stating this is for his Belite Cub. Much of the presentation is pretty basic engine information as the title suggests.
