Hi all,
I'm 64 and I have had a Private Pilot rating since 1986 and in 1999 I earned my commercial rating in hot air balloons. I flew balloons until 2018 and then sold my balloon and I've been flightless ever since. I still dream of owning and flying something with wings.
Due to a medical issue I'm relegated to part 103 Ultralight. I could pursue regaining my medical because the issue was administrative but it would be more costly that it's worth so it's Part 103 for me.
I just learned of the Badland F series and I'm seriously considering building and flying it. I'm glad that there's a new 4-stroke engine in town, namely the Thump Air 460. Perfect timing.
In doing some Google searches I saw that there was an accident in Virginia involving an F3 this summer. No information about the cause was available. I'm glad that the pilot was ok. Does anyone have any more info? Was it an engine failure and a prop-strike/cartwheel upon landing? Pilot error or product issue?
Again, nice to meet you all!
Hello from Bob in Mapleton, Utah
- bobmeister
Re: Hello from Bob in Mapleton, Utah
Hiya, Bob! I hadn't heard of the incident, but after a bit of googling I found it in Aviation Safety Network's website. After pursuing all the links, I did happen across a tiddly bit more info and a single, grainy photo.
Apparently they "had to extricate the pilot", and he was air evaced to a local hospital with non life threatening injuries. Other than cutting his seat belt, I can't imagine what they mean. The photo shows an intact fuselage, sitting atop collapsed landing gear. Approximately one third, to one half of the right wing is damaged.
I could offer assumptions all day, but I am neither an accident investigator, nor even a pilot. I'm just a hillbilly from the mountains of Arizona with too many chainsaws. All that said, I saw nothing in that *single* photo, to indicate that the airframe failed in anyway. The A$$ I make of my self says that this was a powerplant issue, and the pilot made an emergency landing, an eventful one. It may be that the "non life threatening injuries" he sustained was a lump on the head and concussion when the plane whipped around. It's hard to tell exactly from the angle of the single low quality photo, but I think the plane spun when the right wing hit the ground. OR he set it down hard, collapsed the gear, and then the wingtip hit. Either way, not so good for the noggin. Obviously there's lots of other ways to pick up injuries that they'll medevac for. Regardless I hope the pilot has made a full recovery. Hopefully we'll get some more info some day, but that is only likely if he, or someone close to him puts his story on line where a member would find it.
All aircraft are subject to gravity, and a perfectly safe aircraft is still subject to imperfect piloting. I'll take my chances with this company, just like I have to do at work.
Blah blah blah, welcome to the forum from the other new guy! At least you know how to fly, I only know how to fall!
https://www.13newsnow.com/article/news/ ... bfcba77f6e
Above is a link to a local news story. The embedded video includes a second photo, showing the front of the plane. The thing was pretty snarled up. Hard to tell what was crash damage and what was EMT. Didn't spot any blood, which is promising.
Enough of my Monday morning quarter backing.
- bobmeister
Accident was Pilot Error
Hi All,
I asked Chris D. about the accident and it turned out to be 100% admitted pilot error. The pilot took over overweight in gusty conditions. There was a treeline ahead that he was unable to climb over. He banked away at high angle of attack and stall spun into the ground, hitting nose first. So there's no product issue. Important safety tip: Check weight and balance like any good pilot and the required distance to clear a 50 ft obstacle, etc.
Thanks for posting Bobmeister because it saved me the effort. Pilot is apparently healing up nicely the last I heard.
Also, they had to cut away much of the airframe to extricate him. What you see in the photos was not crash damage.
Welcome to the forum Bob. I won't go over the accident as others have done so. I'm in the same boat (or plane situationbobmeister wrote: ↑Thu Oct 05, 2023 8:25 pm Hi all,
By the way, Bob, welcome to the forum!
