Threaded Oratex
Threaded Oratex
So I would like to have multiple colors using Oratex. The problem of course is how would the shrinking work with two different pieces of fabric. Speaking with Chris some time back, Chris mentioned that there is a way to do this, but the two pieces have to be joined and then shrunk together. This seems to be something that would be rather difficult. In fact, Chris mentioned, it is tricky. I was thinking of trying a different route. Now, I would not do this on flight surfaces. What if I cut the Oratex with fingers where it was to be glued to the frame of the plane? Please excuse my drawing below, it's the best I could come up with. Let's say I have red and blue Oratex. What if I cut it, so I could interlace the red and blue around the frame of the plane, wrapping just like would be done if it was a single sheet of Oratex. I was thinking, 1" pieces back and forth might offer enough strength and not cause an issue. The gray is the frame. Then, using some pinked tape, I glue it over the seam. Would this provide enough strength in a non-flight surface area? Ideas, comments? Any other ideas on how to do this multicolored Oratex?
Re: Threaded Oratex
I guess you discovered one of the few disadvantages of Oratex. I've been doing fabric work for 40 yrs and cannot answer that. Joining two sections over a structure shouldn't be an issue. I would just shrink the glue line only enough to remove any wrinkles.
Re: Threaded Oratex
Thanks for the input. I'm thinking that this shouldn't be a problem as long as I keep the sections where each piece feeds through the other small, maybe an inch or so. That should also keep any vibration or stretching problem to a minimum. As long as the section is not under stress, such as a flying surface would be pretty silly to try. Doing this to a flying surface, I might end up testing my BRS at the same time! Then using the pinked tape to cover where the two materials fold over each other, with the glue from Oratex (as I understand, it's super strong) that should hold the two materials together.Mountain Cat wrote: ↑Tue Nov 21, 2023 8:14 am I guess you discovered one of the few disadvantages of Oratex. I've been doing fabric work for 40 yrs and cannot answer that. Joining two sections over a structure shouldn't be an issue. I would just shrink the glue line only enough to remove any wrinkles.
Yep, using material is a blessing and drawback at the same time.
Re: Threaded Oratex
Todd, are you talking about doing something similar to a finger joint when working with wood? (Sorry, I am having a hard time determining what your graphic is demonstrating. I blame it on only being on my first cup of coffee.) If so, that seems like a lot of work and a lot of precision cutting of the material.
I should think that, depending on where you need/want the color change, you could simply overlap the material enough to get a good bond, then add the tape as a layer of protection as well as to straighten the line between colors after shrinking (if need be).
As mentioned before, this glue is remarkably strong, and these aren't F-15s.
Did Chris mention how he handles the multiple color issue on his builds? Now I'm curious!
Re: Threaded Oratex
Sorry, that drawing sort of sucks, but yes, finger joint that would wrap to the back side of the same material. The fingers would only glue to the back of the same material, red to red, blue to blue.LA F2 Flyer wrote: ↑Tue Nov 21, 2023 9:48 am Todd, are you talking about doing something similar to a finger joint when working with wood? (Sorry, I am having a hard time determining what your graphic is demonstrating. I blame it on only being on my first cup of coffee.) If so, that seems like a lot of work and a lot of precision cutting of the material.
The precision cutting would be done with some sort of press cutter using a jig to make sure the cuts are identical.
When talking with Chris, the overlapping is what he mentioned that Oratex offered as a possible solution. The problem comes in with the shrinking. The overlapping has to be shrunk first, then glued together. You can figure this will distort the rest of the fabric making it difficult to install. Chris said he wasn't sure of the full process, but that Oratex noted, it's not easy.
Either way seems there are going to be some difficulties. I would rather put the material on with the fingers, then shrink it all, then cover the seam. Putting the material on partly pre-shrunk sounds more complex. Though my suggested way doesn't give any options for going off line of the frame supports (no curves and such).
As for how Chris handles it... as best I can tell, you're looking at painted birds or those like the silver are all one color with either Oratex pieces just cut and glued directly onto existing fabric or using some auto or RV striping decals.
Re: Threaded Oratex
Auto decals would be your best and easiest option. They can be made to any design and color. And they are not heavy, easy to apply and generally do not come off. Using Oratex is weight saving but limits you somewhat.
Re: Threaded Oratex
Todd, I think you're right - all of Chris's designs seem to be another layer of Oratex over the existing covering to create the patterns. Another issue with overlapping colors is the bleed-through from one color to the next.
Auto decals aren't a bad idea.
Re: Threaded Oratex
I have read about the transparency issue with Oratex, so was looking for a way to hide that. Thinking the pinked tape may do the trick. I'll have to do some testing to decide which method I'll end up using.LA F2 Flyer wrote: ↑Tue Nov 21, 2023 12:14 pm Todd, I think you're right - all of Chris's designs seem to be another layer of Oratex over the existing covering to create the patterns. Another issue with overlapping colors is the bleed-through from one color to the next.
Re: Threaded Oratex
Has anybody used the oratex trim tapes for two color covering jobs? Could you use the trim tape to cover the seam where the two oratex 600 colors meet? Example: a blue upper fuselage with a silver lower fuselage while using a black stripe of oratex trim tape where the blue meets the silver.
Make the stripe a complementary color for your situation.
Re: Threaded Oratex
I use automotive pinstripes to cover the paint line between two different colors. Or a decal/sign shop can make them in whatever width you need or want.
Re: Threaded Oratex
Now THOSE are pretty!
Re: Threaded Oratex
Very sharp! What's your consultation fee? I'm about as artistic as a slug!
