Over the weekend we determined that Polini sent the wrong mount ring for my Thor 303. Chris was all over it he said that Polini sent 2 of the same part numbers with mismatching rings. He's getting my replacement out today.
This morning I tore-down the trial fittings of the controls parts so that I could scotch-brite, clean and hit them with a coat of self-etching primer. They should be ready for 800-grit sanding and white enamel painting tomorrow.
Looking for a local sheet-metal shop with a 2.5" dimple die for the seat bottom and back, Not much luck so far. Also no joy on finding the use of a cable tension meter for the rudder cables install.
Trying to get as much of the fuselage features done before starting work on the wings and flaperons.
Wrong Polini Mount ring and Controls paarts painting
