Control PedalSprings & Quick Release Drain Fitting
The bar positions the rudder Pedal in the neutral position as is the rudder also clamped in the neutral position for setting the control cable length. The L-angle is pop-riveted to the firewall and allows 5 locations for attaching the rudder and brake return springs.
The fuel tank drain quick disconnect is a nylon bulkhead fitting mounted on a bracket pop-riveted to the cross-member behind the seat. The lower portion of the valved fitting will have a length of 1/4" flexible fuel line attached and is inserted into the fitting only to drain the tank.
