New Lift Strut Inserts PROBLEM
Posted: Fri Mar 10, 2023 10:55 am
I got my new replacement lift strut inserts yesterday (also my 10-32 rivnuts via Amazon). I noted that they were of a new design but though that they should work as well as the originals. Bright and early this morning I went out to the hangar/shop and much to my dismay found that the new inserts will not accept the threaded rod end bearings. The shaft of the bearing go in less than a quarter of a turn before they seriously bind. I called and sent an email to Chris. I hope it is a simple fix. I'm hesitant to just tap-out the inserts without the OK from Chris. Otherwise it might mean another 5 week wait for replacement-replacemnt inserts. Bummer!
Re: New Lift Strut Inserts PROBLEM ... coarse vs fine thread
Posted: Fri Mar 10, 2023 1:05 pm
Appears that the new/replacement lift strut inserts have a coarse 5/16" thread and the AN5 rod end bearings provided are fine thread. No reply from Chris as yet.
Posted: Fri Mar 10, 2023 2:04 pm
ksatter26 wrote: ↑Fri Mar 10, 2023 1:05 pm
Hopefully tapping them will be a non-issue. Waiting for an approval to do so from Chris is smart. There's no room for mickey rigging or alterations when it comes to our butts in the air!
Posted: Fri Mar 10, 2023 7:15 pm
I'm not sure what I would do in this situation. Let us know what Chris says.
Posted: Fri Mar 10, 2023 11:16 pm
Posted that Chris is livid with his supplier. Seem that the supplier delivered ALL of the last inserts with coarse threads even those for the elevator (without the left-handed end).
I hope i don't have to wait another 5 weeka.
Posted: Fri Mar 10, 2023 11:59 pm
Wow now that's someone at his suppliers shop not properly reading the spec sheet for the part. Finding suppliers that deliver what was ordered is always fun, just ask Boeing and Airbus. We'll I hope you do get the replacement pieces quickly. In the meantime I suppose there are other little things to take care of.
