Structural and Cosmetic Fiberglass Work Tedious
Putting in the time but the progress seems very slow.
I'd like to get the cowling to the final configuration and clamped in place before I finish screwing down the top of the windscreen to the butt ribs and the L-bracket at the rear of the cockpit. So I'm auto-body puttying the extensions to the cowl cheeks and ears to get a nice smooth final finish. I'm also making patterns in thin fiberglass laminate sheets to optimize ("pretty-up") the somewhat ragged holes I made in the cowl attempting to get a good cowl/windscreen-prop clearance fit.
The pix shows the port-side cheek extension with the auto-body putty (micro-balloons) prior to finish sanding. It also shows the oversized hole in the cowl for the carb/air-filter along with the fiberglass pattern that will be glassed-into the inside of the cowl. I'll than add reinforcing glass and finally micro-balloons for finishing. I'll do the same for the two exhaust piping cut-outs. Lots of sanding to shape and to finish smoothness.
I also fabricated a small u-channel bracket to support the USB GPS receiver. I pop-riveted it to the windscreen mount on the starboard-side. From there I can monitor the small blue signal indicator light.
Re: Structural and Cosmetic Fiberglass Work Tedious
Tedious AND messy! But at least it's not too complicated! Your fixes are looking good.
