Chat GPT
Chat GPT
So for fun, I asked Chat GPT what a Badland F5 was. Here's the response.
The Badland F5 is a type of ultralight aircraft known for its compact design and relatively high performance in the ultralight category. It typically features a simple, lightweight construction aimed at recreational flying. The F5 model is designed for ease of handling and efficiency, often incorporating a single-engine configuration and a high-wing design. It's built to be a cost-effective and accessible option for enthusiasts looking for a fun flying experience.
Not absolutely accurate, but then Chat GPT wasn't designed to be accurate, but still a much better response than any regular search engine. 🙂
Re: Chat GPT
"often incorporating a single-engine configuration" - I'm still scouring the interwebs for that twin! haha
Re: Chat GPT
LA F2 Flyer wrote: Mon Aug 19, 2024 11:05 am "often incorporating a single-engine configuration" - I'm still scouring the interwebs for that twin! haha
I would also like to see the prototype for the low wing and duel engine! Either ChatGPT is way off, or Chris has been keeping secrets!
I also got a kick out of the "relatively high performance in the ultralight category." - when did "high performance" come into play for the ultralight category?
I was a bit surprised that ChatGPT didn't mention the titanium frame. Talk about leaving an important fact out..that would certainly be one of them!
fly44d
Contact:
Re: Chat GPT
Post by fly44d »
Badland-F5 Pilot wrote: Mon Aug 19, 2024 1:36 pm
duel engine!
HAHAHA
AI is so easily fooled.
Tom Hail
Badland F1 built by Chris Deuel
Purchased Nov 2023, first flown Feb 2024
YouTube:
https://youtube.com/playlist?list=PLWfk ... pLWD99TgrT
Re: Chat GPT
Yeah, they forgot to tell us the AI is that of a 6 year old! 😂
Re: Chat GPT - And Another One - UL parachute
And here's why you don't believe anything from the Internet unless you've done a ton of research.
You said:
What is the maximum allowable weight for a US ultralight aircraft with an emergency parachute?
ChatGPT said:
ChatGPT
In the United States, the maximum allowable weight for an ultralight aircraft is generally 254 pounds (115 kg) for the aircraft itself, including all its equipment and fuel. However, if the ultralight aircraft is equipped with an emergency parachute, the maximum weight limit can be increased.
According to the Federal Aviation Administration (FAA) regulations, if an ultralight aircraft is equipped with a ballistic parachute (a type of emergency parachute), the maximum gross weight can be increased by up to 50 pounds, bringing the total allowable weight to 304 pounds (138 kg). This weight limit includes the aircraft, fuel, and any other equipment.
Always ensure to check the latest FAA regulations or consult with the relevant aviation authorities to confirm the current rules and requirements.
You said:
I thought the allowable weight for an emergency parachute was 25 pounds, not 50 pounds. Is this not correct?
ChatGPT said:
ChatGPT
You're right; I misspoke. The correct information is that in the U.S., for ultralight aircraft equipped with an emergency parachute system, the maximum allowable weight increase is indeed 25 pounds, not 50 pounds.
So, with an emergency parachute, the total allowable weight for the ultralight aircraft is 279 pounds (126 kg). This includes the weight of the aircraft itself, fuel, and any other equipment. Thanks for pointing that out, and I appreciate the correction!
Now, AI will be the end of the human race if we listen to it!
:D
Re: Chat GPT
More fun with Chat GPT.
What is the Badland part 103 builders and pilots forum?
The Badland Part 103 Builders and Pilots Forum is an online community or platform specifically for individuals who build, own, or fly ultralight aircraft that fall under Part 103 regulations, particularly those related to Badland Aircraft.
Badland Aircraft manufactures ultralight aircraft kits that meet the FAA's Part 103 standards, allowing them to be flown without a pilot's license or aircraft registration.
In forums like this, members typically discuss various aspects of ultralight aviation, including: Building tips and troubleshooting for assembling Badland Aircraft kits; Flying experiences and stories related to ultralight flying under Part 103 rules; Modifications and upgrades to Badland ultralight aircraft; Maintenance and repair advice; Safety tips and general ultralight flying guidelines.
These forums are useful for hobbyists, builders, and pilots to share their knowledge, ask questions, and get support from others with similar interests.
Couldn't have said it better myself!
Re: Chat GPT
It got THAT one right...a good start!
