F-3 Trailer Build
Re: F-3 Trailer Build
Congrats on the new home and welcome back!
Thanks. I'm not all the way there yet, but making progress. The mini-farm (Chicken's, pig, and farm maintenance) is keeping me rather busy. I'm also trying to get the pole barn in order so I can get a picture of the future Badland F5 Fujita Hanger
ha! Love it! Looking forward to pics of all three - the chickens, the pig AND the pole barn...not necessarily in that order.
I really want to get the pole barn taken care of. That way I can post the picture on the Badland Facebook Group as well as our forum.
After my "incident" a few weeks ago (getting stuck holding the tail of the plane high in the air while yelling for my wife to come rescue me), I decided to go in a different direction with the tail support.
I ended up buying a scissor jack with a 24" lift as well as a small plate of mild steel (4"x1/8"x24"). The intent is to winch the plane all the way up until the tail spring is over the scissor jack, then lift it mechanically. I'm sure my back and my neck (which is still sore) will thank me.
I had to reconcile where to mount the scissor jack so it doesn't interfere with the tail of the plane. As a result the initial plan to keep it simple and mount the jack on top of the rear crossmember had to be rejected.
After some consideration I decided to add a plate just ahead of the crossmember, and supported from underneath so as not to interfere with the jack base.
This is what I came up with.
I welded it into place (again not doing my neck any favors when welding the underside.
It had been predrilled for the jack, and was test fit multiple times to make sure the welds don't interfere with the base, possibly misaligning the bolt holes.
Once the welding was done I threw a coat of primer on it.
Looks great man, nice job and great work around. There's always a way! Looking forward to seeing how it works once completed.
Thanks Todd. Here is the completed look.
The kit also came with a few options to crank it up and down. You can guess which I'll be using most of the time.
Nice. If only I could weld.
The welder I bought was recently on sale at Harbor Freight for $150. I taught myself with one 2 pound spool of wire. It might be worth a shot!
I have one if those. I probably need another couple if pounds of wire and a month or two of practice time.
Very nicely done. Plus, being mechanical, there's no chance you'll be stuck without being able to raise or lower the jack. I think you most likely can even do that by hand if the jack crank is left at home by mistake!LA F2 Flyer wrote: ↑Fri Jun 28, 2024 6:54 pm Thanks Todd. Here is the completed look.
