Magnum Ballistic Parachutes are available for a wide range of aircraft, including Light Sport, Experimental and Ultralights.
Systems are available for aircraft up to 3,960 pounds gross weight, and deployment speeds of up to 199 MPH.
We provide a FREE Loaner Canopy when your system is due for repack!
https://www.uflyit.com/Magnum%20Parachutes%202.htm
Re: Magnum Ballistic Parachutes
Here is a nice option for a BRS. The price is fair, and it's comparatively light.
http://www.newmexicotrikes.com/Comelli/ ... hutes.html
- Contact:
Hi LA F2 Flyer. Are you using the Comelli BRS?LA F2 Flyer wrote: ↑Tue Jan 18, 2022 1:10 pm Here is a nice option for a BRS. The price is fair, and it's comparatively light.
Hi broughtonkicks! I am not. I haven't decided whether or not I intend to install a chute, for a variety of reasons. Right now my center of gravity is at the most aft point of the range, and hanging a chute somewhere behind the center of gravity would put me past the range, I have a feeling.
Also, I rarely intend to fly with enough altitude to deploy it. Unless I decide to hang a much heavier engine on the nose of my plane and decide to do a flight from A to B, rather than buzzing a lakebed, I will likely just go without.
I had come across the site a while back when I was researching what was available, and Comelli seemed like a viable option for a good price.
- Contact:
Thanks for the info LA F2 Flyer. I too am not very concerned about actually needing to deploy it. I am primarily interested in having one so that I can get the extra weight allowance and still comply with Part 103 restrictions.
Barry
F4 Flyer + Doors & Comelli Chute
(Formerly the F3 Speed)
It sounds like it might suit your purposes, then. As I recall one of Comelli's options was lighter than a lot of other chutes I had seen, so it may give you a few extra pounds to play with!
