The Rudder and Brake Pedals are installed in the fuselage with the 5/8" bushing stock provided. However both sets require the pedal 5/8" mounting tubes to be reamed out to remove slight scale on the interior from the welds.
The Tail Wheel is the new solid rod spring design. It went together rather easily.
Tail Wheel, Rudder and Brake Pedals
