On Gar and Camber Setup
Finally got the starboard wheel problems fixed. Solution was to replace the Azuza provided tube with an 8" wheelbarrow tire. Works fine.
I created a jig to set the gear at 61" (outside track width and set camber at 1.5 degrees. The airframe was supported off the gear via my engine hoist then lowered onto the jig. As per the builder's manual, I marked the location on the cabane strut to drill the 3/16" holes for the stop bolts. Note also the trial installation of the tail feathers.
