Control PedalSprings & Quick Release Drain Fitting
Posted: Tue Nov 15, 2022 9:45 am
The bar positions the rudder Pedal in the neutral position as is the rudder also clamped in the neutral position for setting the control cable length. The L-angle is pop-riveted to the firewall and allows 5 locations for attaching the rudder and brake return springs.
The fuel tank drain quick disconnect is a nylon bulkhead fitting mounted on a bracket pop-riveted to the cross-member behind the seat. The lower portion of the valved fitting will have a length of 1/4" flexible fuel line attached and is inserted into the fitting only to drain the tank.
