Warm weather -back to work
Sneaking in some building time between Bowl Games.
Just finished clecoing in the lower flaperon mounts into the port wing. I have match drilled the upper and lower mounts and have the flaperons mounted (via clecos... both wings]. Current thinking is to rivet the flaperons to the wings after covering. (Thoughts?)
With the warm weather I was also able to epoxy the aluminum coverings over the mounts.
During rhe cold week without internet or TV, I hopefully finalized my instrument panel layout. I was given an iPad 6 Mini as a Christmas/birthday gift. The small size (overall 8"x6") allows me to mount it in the center (horizontally). I hope to use the split screen feature to run iFlyGPS and the nice Compass app.
I also have a 2" diameter Swift dual CHT-EGT gauge. The Polini 8x1.00mm EGT sensor probe (part # 938.830.014) is expensive ($72) and I can't find a suitable (cheaper) substitute as the depth of the exhaust pipe is rather small.
Hope to post pictures soon.
Re: Warm weather -back to work
Happy New Year!
I mounted the flaperon mounts first, then covered them. Either way works, but I preferred the cleaner look of the fabric covering the aluminum base plates. Did your gauge not come with both sensors? (Or perhaps it's the Falcon CHT/EGT gauge that comes as a package.)
Looking forward to pics of both the panel and the flaperons. Also the gauge sensor application for EGT. I can't seem to get mine to read, and am thinking I may have mounted it too far from the cylinder exhaust flange. However, there was an existing bung welded to the exhaust at that point which I utilized.
