Ballistic Parachute
- Contact:
Ballistic Parachute
Greeting All! I will be picking up my F3 Speed RTF next month. I am considering adding doors for cold weather flying...however a set of doors weighs 6 lbs., which pushes the plane over the 254 lbs limit. Therefore, I am also considering adding a parachute in order to get the additional weight allowance while complying with Part 103. Has anyone installed a BRS on their Badland Aircraft? If so, where did you install it? What are your thoughts? Thanks for the insight!
Barry
F4 Flyer + Doors & Comelli Chute
(Formerly the F3 Speed)
E014BB
E014BB
Re: Ballistic Parachute
Welcome – I don't have my kit yet, but I'm also planning on getting a BRS to gain some wiggle room for doors and other toys I can squeeze in. The best weight I've seen for a chute is from Magnum Parachutes. They have a chute named the 660 Softpack. It is still a rock lunched chute but comes in at only 15Lbs. Based on our Badland aircraft, it'll easily handle the plane. Remember too, that anything that can be removed and is not needed for flight counts as cargo. As long a flyable plane is below the 254Lbs mark, you're good to go. For this reason, my tablet, radios, GPS, ADS-B, and more will be all removable and not necessary for flight. I'll have some basic steam gauges and that's about it for regulatory purposes. Oh and one of the other things I really like about Magnum is that they send a loaner chute when it comes time to send yours in for inspection and repack.broughtonkicks wrote: ↑Thu May 04, 2023 10:55 am Greeting All! I will be picking up my F3 Speed RTF next month. I am considering adding doors for cold weather flying...however a set of doors weighs 6 lbs., which pushes the plane over the 254 lbs limit. Therefore, I am also considering adding a parachute in order to get the additional weight allowance while complying with Part 103. Has anyone installed a BRS on their Badland Aircraft? If so, where did you install it? What are your thoughts? Thanks for the insight!
https://www.uflyit.com/Magnum%20Parachutes%202.htm
- Contact:
Thanks for the reminder (and clarification) Todd ref. "removeable" doors, etc.
I looked at the Comelli BRS that was mentioned in another post; it only weighs 11 lbs, but I don't know about getting a loaner while it is being repacked.
Thanks again!
~Barry
Thanks again!
~Barry
Barry
E014BB
E014BB
Hey every ounce counts, right? The re-packing I think could be arranged during the time of the year when clear skies don't come too often. That would certainly negate the loaner chute. I'm about to retire and will be heading to Florida, so flying is pretty much year round. Of course August wouldn't be a bad time to take some time off since it's pretty hot. I plan on flying at some altitude, so a chute is pretty much a must for me. I've pretty much settled on the Hirth F-23 for an engine. That should easily give me the HP, and hopefully the F5's 28Lbs lighter frame will give me the weight saves to install the F-23. Even then, Peer's F2 came in way under weight. Chris builds some real ultralight ultralights! I'm also looking at SC2 carburetors for the F-23. These seem to be amazing carbs that auto adjust for altitude and temperature! Plus they show up to 30% less fuel consumption and 15% more HP. Check them out here: https://smartcarbfuelsystems.com/ and do a search on YouTube for SC2 Carbs. There are plenty of reviews and I haven't found one negative. The only question is, there are only a few ultralights that have used them, so how well will they work on an F-23 engine?broughtonkicks wrote: ↑Thu May 04, 2023 3:16 pm Thanks for the reminder (and clarification) Todd ref. "removeable" doors, etc.
Thanks again!
~Barry
Lots of adventures coming in the future once I get my kit. Hopefully that'll happen in the latter part of this year. I envy you getting your plane soon, and Kurt as he builds his. He's doing a great job of showing his build. Are you buying a kit or is Chris building for you?
