Flaperon control cables routing
Posted: Sat May 06, 2023 12:22 pm
Change of pace ...
Checking the routing of the flaperon control cables from the elevator actuator arm aft of the pilot seat to the flaperon control arm molnted to the flaperon spars. Generally looking to see where the cables should be located to pass thru the Badland (butt) rib and #1 wing rib such that there is no binding .
I did secure the cables to the frame near the point where they exit under the seat and start the looping curves up to the wings.
The above picture also shows the quick release drain fitting from the bottom of the fuel tank. As part of my "Fly Kit" I have a short length of quick connect/disconnect tubing.
The routings seem to look good with no binding and the wings fold well.
Also it looks like I'll be doing some serious trimming of thee nose portion of the bubble cowl to get prop clearance.
