Cowling Cheek Extensions - Figerglass
Posted: Mon May 15, 2023 5:10 pm
I started the messy fiberglass cowl cheek extensions. I laid out the curve of the cowling and extended the shape 2.5" on either side of the shape line.
I then covered the pattern outline with waxed paper and did (the messy part) 2 layers 0f 1.5 oz boat cloth. The process required but 2.5 oz of resin mixture. I've never used the waxed paper method, but even if it doesn't easily peal off, I can lightly sand it away. I'll post more on this experiment when I try it. The resulting shape should be flexible enough to fiberglass onto the inside of the cowling and I can feather the extensions into the cowling with resin and micro-balloons. The plan is to add small 0.016" patches of aluminum at the air-frame mounting tab points.
I also created a 1/8" gasket rubber mounting ring to attach the low profile air filter to the carb.
