Some Progress and Old Problems
Posted: Sun Dec 10, 2023 11:09 am
Progress: Both flaperons covered in Sky Blue Oratex. I suggest that the 1st time Oratex user start with a flaperon as there are no complex curves to cover. The only difficulties I had with the flaperon process was handling the length alone. I did add Oratex doublers over the hinge slots.
My roll of FIXING tape arrived and it works really well. It seals against the Oratex and itself well; peels away cleanly leaving a nice straight demarcation line between the glue and the fabric. I'll probably order at least one more roll for use on the wings, and tail-feathers.
Problems: The old Polini no spark problem is back. I re-installed the engine that I got back from London Ivey in Tampa. It was purring as advertised in the video that London sent me. I held off a few weeks re-installing the engine as I completed covering the fuselage/air-frame with Oratex. Once I remounted the engine I attempted a startup and got a really weak turnover of the starter motor. I pulled the plug and verified that I had a spark. I had been informed that the starter motor likes a nice high amperage and above 13vdc. My battery was at 12.7vdc so I replaced it with a 13.3vdc battery and tried again. The crank was somewhat stronger, but no startup and after 3-4 tries, the new battery was down to 12.5vdc. while the batteries were on my charger, I moved my grounding wires from under a cyinder head bolt to the aluminum CDI mount where all of the original grounding had been done. This was at the suggestion of London becuse he indicated that the cylinder head bolts need to be torqued down pretty tight .
I replaced the battery and tried again with the new groundings. No joy. I once again pulled the plug ... no spark. I replaced the plug with a new one, also no spark. I took the kill switch out of the circuit, No spark. I isolated the electricals such that all I had was the motorcycle push button starter switch connected ... No spark.
Truly frustrated, I again removed ALL of the grounds and connected to a small terminal block with one wired connection to the original grounding location on the aluminum CDI bracket bolted directly to the engine. Still no joy ... no spark.
I have only one other possibility to test today. The possibility that the aluminum CDI mount bracket is not providing a sufficient grounding contact. I will check the continuity today.
My Polini has been a nightmare.
