FAA Part 91
Searching for that specific fix, modification, or other information that you once read in one of the forums? It might be here. When the admins find information that is useful but sometimes gets lost in other forums, we'll move it here to easily find it. So think of this as anything outside of general discussion.
Locked
FAA Part 91
Part 91 contains some information that is applicable even to ultralights. This isn't about the plane itself but discusses how you can use your ultralight - simply what you can and can't do with it. It's not all applicable, but some of it is at minimum, good to know info.
FAA-Part91.docx
(8.2 KiB) Downloaded 228 times
Locked
